Configure the SPB-PIM Gateway interface parameters on a VLAN.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select VLANs.
  3. Select the Basic tab.
  4. Select a row for the VLAN, and then select IP.
  5. Select the SPB-PIM-GW tab.
  6. In HelloInterval, type the hello transmission interval.
  7. In JoinPruneInterval, type the join prune transmission interval.
  8. Select Apply.
SPB-PIM-GW Field Descriptions
Use the data in the following table to use the SPB-PIM-GW tab.
Name
Description
OperState
Displays the current operational state of this SPB-PIM Gateway interface.
Address
Displays the primary IP address of this router on this SPB-PIM Gateway interface.
AddressMask
Displays the primary IP address mask of this router on this SPB-PIM Gateway interface.
HelloInterval
Configures the PIM HELLO transmission interval. This SPB-PIM Gateway VLAN level interval setting overrides the inherited global SPB-PIM Gateway HELLO interval setting. Setting the HELLO Interval to 0 causes the neighbors to never expire its neighborship with this local SPB-PIM Gateway interface.
JoinPruneInterval
Configures the PIM JOIN PRUNE transmission interval. This SPB-PIM Gateway VLAN level interval setting overrides the inherited global level JOIN PRUNE transmission interval setting.
